81 - 100 of 212 Posts
Discussion starter · #85 ·
would not the 6-speed enable me to cruise on the highway at a lower RPM than 3500?
Yes slightly...but, IMO the amount of gas you will actually save wont justify the cost of the transmission...unless you drive it for ten years or more, and that's assuming you don't replace any parts which is inevitable i.e. clutch, ball joints etc...
oh yeah i wouldn't actually go and buy one now, but it would be preferred if it had come with a 6-speed
Discussion starter · #87 ·
Realtune catless downpipe ordered and on the way...once.that gets here we can connect the engine harness and see what happens when we turn the ignition over...fingers crossed
Discussion starter · #89 ·
Well I was gone for a bit, but I'm glad you decided to keep this baby. Hopefully we'll see new pics of it flying down the track!
probably not till spring for those lol im tryig to concentrate on it running with no problems first lol...hopefully i get 13.90s first time back out
Discussion starter · #90 ·
So...slowly this project is coming together...had to drop the oil pan and do some cleaning...when removing and inspecting oil filter some sludge came out so we decided to be safe than sorry and went ahead with cleaning...also waiting for some parts from dodge: new belt and stuff like that so we can fire this baby up...sorry for the slow responses,will take pics monday or tuesday
Reactions: Francois
Sweet!! can't wait to see the final results.:smileup:
Discussion starter · #92 · (Edited)
hey all...here is where we are at right now...things are going well. The SRT wiring harnesses and ECU have be installed routed the same way the R/T ones were..they were VERY similar so no problem installing there, just a simple take out and replace with SRT harness...the 5speed tranny and srt clutch bolted up to the engine perfectly and the motor is now installed in the car with race mpx motor mount inserts. im not too worried about the vibrations...ill get used to it...if its really a bother ill jsut take them out later... right now we are waiting on an order of parts from dodge
upper rad hose
new belt
heater hoses (damaged when blew motor)
little things like that
i think they came out to about $250...no too bad
the Realtune catless DP installed and bolted up perfectly with no problems
the next step is to drop the oil pan and do a little cleaning. after everything comes in and gets installed we can fire up the beast and see where we are at....thats all i got for now...will try to keep it updated more frequently...any questions please ask
Hrm. Didn't you suggest at some point you didn't have the SRT4 ECU yet?
You're going to want to get that or the engine might not even fire. There are a bunch out there selling their Stage 1 ECUs because of the upcoming RealTune MS1K flash.
Keep us posted.
Discussion starter · #94 ·
Keep us posted.
no no..i dont have the MS1 ecu...i do have factory srt ecu..came with the motor deal....:smileup:..i know that...that was my first question when i bought the motor...ill update it and add that in to avoid confusion
damn thats nice... glad it works so well...
Discussion starter · #96 ·
will be going to the shop for an update thursday! will let you all know whats going on...I am going to Toronto to visit my parents for new years so hopefully when I get back the swap will be complete and i will be ready to roll! fingers crossed! :Racing:
Discussion starter · #98 ·
so...here is the problem we have run into now.....it starts perfectly....UNTIL...the Imobilizer kicks in because the R/T key and imobilizer dont match the ECU....so the solution....basic setup i had before... use the N/A ECU and FIC to make the motor run properly...this means 125mph limiter (ugh) which is good for about an at best low 12s car with the right traction....but more HP potential right outa the gate....it is that or....buy a matching ECU,imobilizer and Keys from dodge ($2500 which is a NO at the moment) or piggy back the R/T ecu with the FIC which is what we are going to do....so i am basically going to have my R/T setup with an SRT4 block...lol...probably going to get the to tune it to 18psi if possible until i can afford either an SRT4 or those three things mentioned above....until then....NO MS1K for me :(.....thats what i got so far.....should be 100% done in the next week or so...gotta hook up and tune the FIC then we are good to go....
Would you be able to put in the srt4 ecu that you have in there, and take the vin from the srt4 that the ecu came from, and get a new ignition cylinder made, and a new key cut?
might not be that cheap, but i cant imagine that it would be the 2500 bucks
Discussion starter · #100 ·
I probably could down the road...but right now I need my car...I leave for spring training.the 28th so I need a working running car in the next few weeks... never thought I would take this long...but it is what it is. It'll work this way so its the way I have to do it at the moment
