nice build! how much did the srt4 motor run you? I apologize i skimmed through the 10pgs
the motor was $1600 w/ turbo wiring harness, ECU, Clutch and SRT cluster, got it from a member on calibersrt4(DOT)net from a wrecked CSRT....its all the little things if you are even going to attempt this...which i dont recommend...I already had an intercooler...piping FIC, and all that to make it work.....if are are thinking about doing this...be preparred to pay ALOT of labor and a lot of little parts (that aren't cheap.... heres an idea for you if you have an N/A Caliber w/ manual trans b/c CVT would make it impossible to do any kind of work like this...
the minimum needed with N/A Cali
FIC $300
intercooler $600+
piping $250-500
tuning $500-750
Injectors $500+
High pressure Fuel Pump $400
turbo $1200 +
oil lines for turbo $300
gauges $500 +
Pistons and rods to handle boost $1000+
SRT clutch or custom made $700+
FOR A GRAND TOTAL in parts of about $5100-$6500 WITHOUT labor
and if you want to do a swap...
SRT4 engine $1500 average w/o turbo
turbo $800+
then LABOR Average $75-120/hr
GOOD LUCK....if i would i could do it all over..just trade in for an SRT4...my work was dont before the SRT came out and if i didnt have so much $ sunk into it already...i would have an srt4....if you wanted to go to the shop that did my setup originally..they now charge (for the same work i had done) $8800 for turbo setup..6 psi tune, No internal upgrades... that would put an r/t at about 240-250 whp.... not really worth it...where you can now put about $4000-$6000 into an SRT4 and have a close to 400 HP car
