Some electrical issues on this car can be rectified by resetting the TIPM/PCM. TIPM a fancy name for the computer (PCM) controlled/monitored fuse box on these cars. Doing it correctly is a must:
- Remove ignition key
- Remove negative cable from battery
- Remove positive cable from battery
- Keeping cables clear of the battery, hold them together for 10 minutes (there will be initial sparking as power is drained from the system)
- After 10 minutes, reconnect the positive cable followed by the negative cable.
