Just a curious thought that popped in my head.
Since the Calibers are out of production for over a decade, I thought maybe some owners may have some issues on their cars that they are not repairing for various reasons. I just became curious what those reasons are. Maybe someone can come up with a solution or find some common problems.
And since I came up with the idea, I might as well start it off with my own.
As you can see, mine is mostly due to cost compared to the gains. So, what do you guys have? Is your Caliber in mint condition or does it have some defects that you look away?
Edit) Few more things I forgot to add to the list:
- Different front suspension spring: found out years after ownership that R/H front suspension spring is a softer spring used for SE and SXT, not for R/T. Hasn't given me an issue yet so I'm just using it as is.
- Weak power window regulator: opens and closes the window slower than the others but it still works so I'm just letting it be.
- Various exterior and interior cosmetics damage: mostly wear and tear from normal use, and a lot of broken tabs from repeated removal but they are holding their places.
- Engine stalling after refuel: this probably is the biggest one I have. I searched throughly to realize that it is a common issue and is very expensive to repair compared to a simple remedy which is to not top the gas tank up. Even if I forget and fill it to the brim, I can always apply throttle when the engine is about to stall.
- Premature nozzle clicking during refuel: Doesn't happen all the time but when it does, it's really frustrating. the only way to refuel when the symptom occurs is to squeeze the trigger slowly until I find the sweetspot to not trigger auto-shutoff.
- O2 sensor triggering P0139 code: I've replaced both O2 sensors and exhaust manifold (a.k.a. maniverter). The old manifold had cracks that caused obvious exhaust leak so that had to be replaced, but the code still pops up every now and then.
- Rear hatch struts: No, I do not hold the hatch with my head or my hands while accessing cargo area. But the hatch won't raise on its own and hold whatever the angle the hatch is raised to.
