I have an occasional problem with my 08 caliber. It starts fine and runs good most of the time but occasionally after I start the engine it will bog down once after a few seconds, then after about 20 seconds it will die. Immediately after shutting off something will click 3 time, wait about 10 seconds, click 3 more times, and then again after 10 seconds. But then it will start fine for a while. Any help would be appreciated.
I'm no pro but sounds like an issue possibly with the fuel pump relay? I'd do some searching on that if nobody else chimes in :)
When it dies turn off the key, then turn the key to the ON position (the position before you would actually start to crank it) and listen for a quiet hum from the rear of the car that will last 2-3 seconds. That's the fuel pump priming. If you don't hear that whine, then your fuel pump and/or the wiring to it is suspect. The electrical connection on the top of the pump is known for sometimes corroding or having heat-related damage...you can easily check that by removing the rear seat bottom and then removing the access panel you'll find underneath it...that'll expose the top of the fuel tank where the pump is located.
