There's a TSB for the MyGIG RBZ/RB2. It concerns vehicles built between 05/01/2011 and 01/10/2012 and equipped with MyGIG RBZ/RB2. The MyGIG can wake up after the vehicle was shut down and drain the battery.
==> http://www.wk2jeeps.com/tsb/tsb_wk2_0802512.pdf
The problem will be solved by a software update. Even if your vehicle is pre-may-2011 built you can update the software of your RBZ/RB2. My RB2, for instance, had the application 08.03.02 and now the newest 10.00.11.
Since the site http://mofv.com/mygig/ does not support the RBZ/RB2 you can pm me. There's a German Chrysler Forum that provides that update. I can lead you.
The file size is about 17 MB only and it takes about 10 minutes.
UN4GTBL made a thread about how to update a MyGIG:
http://caliberforumz.com/showthread.php?p=238186
If you are unexperienced with updating a MyGIG I recommend you to visit your Dodge dealer.
Reactions: Prop1
does the RBZ have a RCA output for a subwoofer on the back?
My RB2 has the Boston Acoustics incl. subwoofer. Yet I suppose you mean these cables, don't you:
There's no separate RCA output on the back of the RBZ/RB2.
Those are stereo RCA outputs.
A subwoofer is usually a single channel drive.
OK, but there's also no single channel output (as far as I remember).
