1 - 10 of 10 Posts
As soon as I am opening the trunk on my 07' Dodge Caliber SXT it just closes right away unless I am standing there holding it up. It starts to get really annoying having the hatch back hit my head every time I am trying to load/unload something.
The problem started last winter, and at first it only occurred when it was really cold outside (below zero temperature) and I was parking on a hill (my driveway). Then this spring when it got warmer it started to work fine again, until now, when the temperature outside went down below 40F. Now it is a lot worse, the trunk won't even stay open when my Caliber is parked leveled.
Is this a warranty issue? Is this something I can fix this myself, then how? Do I have to take it to a work shop? Anyone else having the same problem? Would it be expensive to fix?
You need to replace the gas charged liftgate props. They are simple to unbolt and put new ones on. If you still have warranty left, they may be covered, but I suspect they will be considered a wear item.
You can get the liftgate struts from NAPA (about $30.00 each) - they are usually a DIY repair project.
You can also get them from Autozone or Advance Auto Parts. Prices vary depending on what length you need.
After a search this thread is the closest I could find to the problem I'm having except it's just the opposite. Over the past couple days I've noticed the trunk is a bit more difficult to close than it used to be. Can the gas struts be lubricated? If yes, with what?
Try some silicone spray lubricant.
Mine is getting harder to pull down initially - so I'll need to lube.
The latching operation is fine.
1 - 10 of 10 Posts
