Hi,
Reaching out to try to find a fix to these issues. 2011 Dodge Caliber Mainstreet with an intermittent TC problem. C1000, brake pedal switch replaced, a bit of oil above the brake pedal. Assuming an issue with the master cylinder? C1020, RL wheel speed sensor circuit, I have replaced all 4 wheel speed sensors. C1028 RR wheel speed sensor, replaced as noted above. C1035, Right ear wheel speed comparative Performance and C1032, RR wheel speed sensor signal. My mechanic checked all connections of the wheel sensors and replaced the RR wheel sensor that I installed. Said it did not have current going through it. All codes went away after replacing that one. Though, a week later the TC light came back on and no cruise control. shut off the car and re start it, the TC light goes out, cruise returns. No braking issues or performance problems. Could the ABS module cause an intermittent issue as noted above. The wheel bearings have also been checked and found to be in good shape. Thanks in advance.
