I have a 2008 Dodge Caliber 1.8L 5spd with the mopar hitch installed (the one with the 90 degree angle bracket)
I used the hitch a few times to tow a few small utility trailers, etc.
When I moved last year I towed a 5'x9' trailer about 40 miles that weighed a total of just over 3000lbs (quite a bit over the maximum weight) The car handled fine (breaking, turning etc) It was mostly highway and I was able to maintain 60 in 5th on flat terrain.
Recently my 1983 Starion (2700lbs) threw a rod. I need to move it about 40 miles from my house to the storage unit where it will sit until the V8 engine is finished.
I have a car trailer available to me (weighs about 2200lbs) putting the total trailer weight at around 5000lbs.
I understand the extreme wear and tear it will put on the engine and transmission and the fact I probably wont be able to move at highway speeds.
However, my question is will the hitch (rated 1500lbs) angle bracket (rated 2000lbs) and 2" ball (rated 3000lbs) not be able to pull the weight and break?
This is a one time move about 40 miles until the engine goes in.
Otherwise I'll have to pay a tow truck to tow it 40 miles for me.
That or push the car as far from the house I can and see if I can get AAA to pay for the tow.
Thoughts? Other than "remind me to never buy a car that you have owned"
** Edited for typos **
