Timing Marks Dodge Caliber CRD 2.0L
10367 Views 6 Replies 2 Participants Last post by  672aq
Hi, i have recently just did a water pump replacement on my dodge caliber as the old one completely seized up on me, and to do it you needed to undo tension on the timing belt to be able to get the water pump out, and when i got everything back together and took it for a drive everything was fine and when i checked for errors on an obd2 scanner it came up with a crankshaft position sensor error. But of course i knew that the issue was my timing is out by the tiniest bit, right? because the engine runs fine no stalling etc, it just needs to be adjusted properly. I can't seem to find a timing mark on the bottom end but i have marks on the camshaft gears, just not the block. Any ideas or diagrams as to where the crankshaft should be aligned? maybe i'm just dumb? i was thinking it had something to do with that cast notch but i'm not sure, i'll try and do some more research and see where it actually lines up, because i haven't gotten much information from diagrams on google images, cheers
16744
See less See more
1 - 7 of 7 Posts
nvm, i just found this video
which shows the process of getting the engine at TDC and aligning the camshaft gears as well as replacing timing belt, water pump, tensioner, etc. if anyone needs this information it will be here to look back on.
This is the Caliber forum.
You're working on a Dodge Shadow.
The video is for VW.
You may be have Corona.
Reactions: 1
If you look in the description of the video it says it's an audi A6, but it still is a very similar process for vw diesel engines.
Where is a timing belt on your Caliber?
Why does your Caliber have a VW engine?
i have the CRD variant of the caliber which was firstly introduced in the eu, but i am in australia, which has a vw 2.0 crd engine.
I understand now.
This might help:
1 - 7 of 7 Posts
