I’m getting her ready for paint the question is can the outside window (black frame) that always turns white, can it be taken off. Thanks
It's been tried, does not look good. A lot of work with goobegone and polishing. Easier to stick a cover panel on surely, or new vinyl if that's your thing.
On the other hand as your doing a respray I'd go at it with a sander.
OK not to bad but you have to work harder then you think. There is 1 screw in the front doors and 2 in the back. Then it’s matters of pulling up and working it out. The front works from door handle In and the back door works from the car side out to the handle.
16881
16882
16883
