I will let you know. I found a guy on youtube with them and followed him to his tiktok. Seemed like he was having issues with them. I tried asking a few questions and the only response I got was "adjustable sway bar end links" so I got those. I went with Whiteline 223320,223321 . Hopefully someone on here can tell me if I should replace anything else. The front frame crossmember cradle looks okay(Rust issues are common) However, my cali had bad struts for a long time in the front. Nothing catastrophic as far as I can tell. Do I need bushings for under the adjustable camber plates on these? I will replace front stabilizer bar bushings with Mopar because a guy on here had issues with MOOG ones, and the rear with
TRW JBU1275.
Will try to document my experience, as front struts go bad often on Calibers and TRQ, MOOG, and especially mopar cost almost the same amount for loaded struts/springs. This kit is only $580 on Carid.com. A little info, these are old struts. Came out super long ago compared to other cheap ebay struts. The company that delivered them was FATBOY garage in LA... Same company that makes
Rev9 Hyperstreet coilovers. From what I can see these look a little nicer but time will tell.
