There are two cables from the box to engine sensors.
If you did not install it yourself you might struggle to locate the original cables.
They do not have much slack so they will be nearby with the same connector ends.
It will not affect your emissions. Do you have any OBDII codes?
Take it into an independent who knows VW engines for advice. They will quickly be able to swap the leads to give you confirmation.
Did you have the Startech installed by a Chrysler dealer?
