I have a Dodge Calibre 2007 SXT and yesterday coming home from work I was turning and put my signal light on and there was no noise. The lights all work right, left and hazards but I do not hear the noise the signals or hazards should make.
Do you think its the fuse or realy and if one or the other where is it located.
Thank You
The turn signal noise is just that so you if you turned it on , it
is generated by the pc board for the dash display and is part of
its circuitry.
You may want try disconnecting the negative battery terminal
for 10 minutes or so and see if it's as simple as a TIPM reset.
