1 - 7 of 7 Posts
Car will crank normal but will not start.I am now at a loss. Any suggestions on what I need to look for.next? Here is what I've done so far...
*Oil level good
*Has fuel
*Has spark on all cylinders.
*checked and replaces camshaft and crank sensors (Had a check engine light for camshaft)
*Throttle body new
*All cylinder compression around 105psi.
* fuses check good.
No check engine lights. About a week ago it had a camshaft position sensor fault and I replace those then.
When my camshaft position sensor failed, it was because of faulty wires. The coating they put on the wires to protect from corroding are a treat for mice they Love it. I finally found it was a short in wiring, but my car would suddenly light up all the positions Drive, reverse, park, etc...and then not move. Did that happen before you replaced the sensor? Other possibility I was thinking was maybe you have some fuses blown and not allowing errors to be read? You should be able to put it on a computer like John mentioned.
1 - 7 of 7 Posts
