Hi everyone!
My Calibre is brand new (just picked it up before Christmas), and has less than 300km on it (I'm in Canada). It's a 5 spd manual transmission, and yesterday morning it would not shift into gear (any gear) to save my life. It's pretty cold here (-35C), but the car ran for almost 25 minutes and engine temperature read as warm enough to operate. I park with my E-Brake all the time (habit of a stick driver), so released the brake and tried to shift into reverse from 1st with no luck. It went to neutral, but would not move to gear. Tried then to shift back to 1st (thought perhaps it was stuck due to snow underneath or something, and I'd pull forward a dash to loosen it), and was unable to do that either.
Double clutched, tried every gear, cramped my leg pushing clutch through the darn floor, and used full force to try and shift to any gear, all with no success. Shut the car off (still in neutral) and tried using shifter again. Car shifted smooth and easy, into all 5 gears while car was off. Turned it on again, tried to shift back to first, and problem was back.
I was so excited about the car when we first bought it, but this isn't the first issue (in less than a month), and I'm fast becoming remorseful about the buy. Tried reading the 5 spd Tranny problem thread, but seemed that the issue for Dave was double clutching, which I'm already doing and it still isn't working. Both my husband and I drive stick (he's from Europe, I was raised by a mechanic
), so we're pretty comfortable with manual.
Anyone have any ideas? I`ve kind of ruled out clutch or transmission itself, since it shifts just fine when it`s not running. I do have an appt with service at my dealership for today, but wanted to go in with some info if I can get it.
Thanks for reading!
Thanks for reading!
