Symptoms:
Random Misfire on cylinders 1 and 4. (Says the computer, does not feel like it.)
Engine light on, sometimes flashing, sometimes 'dings'.
Car is getting almost 1/2 as many miles per tank of gas that it used to.
Checked and tried a lot of stuff myself. Finally gave up and took it to the dealer, after hours of testing and a bunch of parts, still don't know.
What it is not:
Plugs: tried different different plugs, dealer put in new plugs, swapped plugs to non-misfire cylinders
Coils: tried different coils (from parts car), swapped coils to non-misfire cylinders
Fuel injector: tried different injectors and fuel rail, swapped injectors to non-misfire cylinders
Compression: 150 to 175psi each on a couple of cranks
Pressure?: dealer did a pressure test on cylinders, said engine is tight, nothing wrong that way.
Vacuum Leak: computer says -10 at idle, sprayed ether around intake, no difference in idle.
Crank sensor: Car had also been going into limp mode. Crank sensor fixed that, but not this.
Cam sensor: tried a different cam sensor.
Carbon cleaning: ran a couple bottles of seafoam cleaner through it, no change.
My Bluetooth tool only says Random cylinder misfire, dealer tool was able to tell it is cylinders 1 and 4.
Visually checked wiring for any signs of damage, cleaned up grounds, etc.
They said if it was an O2 sensor, or any other sensor, there should be a code for that too.
They thought about flashing PCM but said it probably would not cause or fix this issue.
Anyone ever run into this before? Or have any idea what this could be?
Thanks for any help.
