Hi everyone,
I have a 2.0 CRD Caliber with BSY code engine.
Recently we took the car to the mechanic and replaced the Dual mass flywheel in the car because we had a clutch issue with the hydraulic clutch slave cylinder, so we replaced all the parts in there.
After that replacement, we have an issue where the car sometimes stops (stalling) on idle, and you can't start the car again after that happens, only if you take off the battery terminals and the connector from the ECU. No engine codes, the car was working before the DMF replacement, now it's just gambling where you hope the car doesn't stop.
I searched for this problem, asked people in some other places, some people said it's probably the crankshaft position sensor, maybe it is, but I asked here if someone had the same issue and could help.
