Ok so I am planning on installing some emergency lights on the ride for work since I sometimes shoot radar from an unmarked car I didn't want a bunch of toggle switches mounted everywhere so I opted this route.
Step one rip the console apart for wire routing
Step 2 remove said console for work
Step 3 install power block & switch pad from pilot
Pressure pad switch close up
I ran a direct power line with a 15 amp fuse from the batt to it and used the emer. brake as a central ground. The fun has just begun though because the lights I want to install will be no easy task.
Man, that's a clean look. Very impressive. Reps to you for that.
