2007 Dodge Caliber:
The front passenger side window will not roll up. Replaced the regulator and motor and the window did roll down but will not roll back up, regardless if I use the driver side switch or the passenger side switch. The window lock is NOT engaged. Fuse is good.
I'm not sure what else to check.
Would both switches not work if one were bad?
Have both switches simultaneously gone bad in use for the passenger side only?
Wires bad somewhere?
Any help would be greatly appreciated!
Thanks!
Thanks!
