My 2007 Dodge Caliber's front passenger window rolls down fine, but now will not roll up with either the switch on the door or the master switch on the driver's side. I was trying to remove the door panel to be able to get to the switch and motor to either repair or replace the switch or to just arc some electricity to the motor to get the window up at least. I've located screws under the door handle, inside the armrest, and two at the bottom of the door, but after removing them all I still can't get the door panel off! Is there another screw somewhere I can't seem to find I need to take off? Is there an easier way to get to the switch without having to remove the entire door? Should I be doing all of this on the driver's side master switch and not worrying about the slave switch on the passenger door? (Oh, all the other windows go up and down just fine with their individual switches as well as the master switch - only the front passenger one is not working). Any help/tips/advice/opinions on this would be greatly appreciated!!! Especially as we're in the middle of a cold snap here in FL, so driving with the window down would be a real pain in the butt!! I've had experience replacing the switches and motors in my Dad's car, so not a complete novice at this - I just can't get the damned door panel off to fix my own!
Thanks in advance!!:doh:
