Car won't start, cluster panel lit up, headlights on, says NOBU5 any ideas?
There's a whole bunch of info for this if you google NOBU5.
Basically, there is no communication to the speedo/tach cluster.
Water got into wiring, bad ground wire, loose connector or sensor somewhere, bad cluster...
What did you do before this problem popped up?
Bought the car with the problem. I found a break in the wire from the battery to fuse panel. Replaced it now I have security light flashing so I have to reset the alarm.
