  • JBL 12" SUBWOOFER (MAX OUTPUT 1200 WATTS)
  • PORTED ENCLOSURE (SINGLE)
Now to my questions and concerns.
1. I want to mount the amplifier under the passenger seat, I have my mind set on grounding it somewhere near the spare tire underneath the cargo area.
2. Sub-woofer is going to be in the cargo area of course. **DOES ANYONE KNOW FROM EXPERIENCE** should I set it up on the driver side or the passenger side.
3. I have an 07 SE, where is a place to run the wires from the engine compartment to the cabin.
THANKS IN ADVANCE FOR THE COMMENTS AND ANSWERS.:Hey:
First off, you wanna ground the amp off as close to the amp as possible.
And to run the wires, by the gas pedal is where the ac drain hose is, mine for my amp fit right through there perfectly. I have mine on the left side, since it was to my amp.
Keep your ground to a MAX of 3ft.
Try the sub in different areas and see if you notice a difference.
I drilled a hole in the firewall and used a grommet.
