· Registered
Font Screenshot Technology Software Electronic device
I have these codes and wanting to get help, opinion, and advice
The car idles around 1 to 2 rpm
P0700
P161B
U1418
This is almost probably worth mentioning this when I drive it to the next County over (~16 miles) on the drive back home this light comes on and then car is in limp mode
Gauge Measuring instrument Motor vehicle Auto part Circle
What should I do I been doing most of the work myself I did take it to the local transmission
shop here and done fluid change , flush , and Inspection and they let us know they couldn’t find anything wrong with it
· Registered
P0700
P161B
U1418
Mine does the same thing. I have to wait about 2 to 2 and half hours for it cool back down before I can go anywhere. I also noticed I go through coolant like crazy and my engine smokes a little on the backside of it. All I do is drive it to work and back and sometimes the store and back and that’s it. It gets me around town and that’s all I need it to do. Might want to check your thermostats. They’re located back under the air filter under the hood. You’ll have to take your battery and the battery stand out.
· Registered
Please let me know if you figure out the problem for I have the same problem. Done everything I can think of changed fluid and both filters, added a external cooler. Really weird trans runs great, shifts properly and all gears work with no problems and there's no noise. Thing is it seems to run fine in winter and has problems in the summer. I would greatly appreciate it if you find the cause and pass it on to me.
Your Caliber bro, Bill
· Super Moderator
Do you mean the original cooler ?
Automotive lighting Headlamp Nickel Font Jewellery
As you are still over heating does sound like a circulation issue, something crimped or blocked. Maybe a flush was required before new fluid.
· Registered
Hello, I have the exact same problem as you. I changed the fluid and both filters and also added a external cooler still overheats in summer as yours and your right this is totally weird trans shifts and runs great no noise. So please if you figure out the problem let me know, thanks and best of luck
