Well, it has to be going SOMEWHERE.
Check your coolant...make sure it's not looking milky. If it is, you have a blown head gasket. If you're not seeing any puddles under the car in the morning then you could be burning it. Rev up the car and see if you're blowing any blue-ish smoke..that's the sign of oil burning.
You could always try doing a leak-down test. Take out the spark plugs and connect a smoke machine or an air compressor to the oil filler hole, pump in some air, and see how much air is coming out of the spark plug holes. There should be little to no air coming out of the spark plug holes but If you get an appreciable amount out of any of them then oil is getting past your rings and burning.
And no, engine problems of this nature are not common with the Caliber...the engine itself is pretty solid on these rigs.
