1 - 12 of 12 Posts
Hey all,
So for the past few weeks I have been having a problem with my alarm, and I have no idea what could be causing it.
Keep in mind I have a euro spec Caliber. The Key fob has only the 2 buttons, Lock and Unlock (if i open the key there is a place for a Panic button but they have it blocked to where you can not push it unless you open the key as if changing the battery)
I first noticed my problem when I locked my door and then about 30 min later I returned and pressed the lock button again by mistake, it set off my panic alarm. Ive done this before and never had a problem until recently.
Now it has escalated to the point where I can lock my door and then anywhere after 2 hours or more later the panic alarm will go off by itself. The first time I thought someone was breaking into my car but that wasnt true, then I thought I could be pressing the lock button by mistake causing it to do it, but just the other day I had my keys in the house and I was standing next to my car, talking to a friend when it went off.
I havent done any electrical work except radio, Amp and speakers. (which I did when I first bought the car almost 3 years ago)
The only thing I havent tried yet is changing the battery in the key, but I dont think that can be the reason... can it? Its the original battery from when I bought the car new in 2009 (but its a 2007 model... it was at the dealer for 2 years untouched)
Any suggestions would be helpful. Thanks
What makes you think it is a panic alarm ?
If your car alarm is triggering too often then there is a TSB to adjust the sensitivity.
It is in our TSB section.
I had mine done too. The internal sensor was registering air pressure caused by passing vehicles.
Wow thanks I would have never guessed there was a TSB for this! Thanks a bunch! I guess I will be heading to the dealer tomorrow, I hope this solves my problem.
Your car battery could also be going bad.
Export Calibers have factory alarms as standard.
Very different to older aftermarket installs that were difficult to tune satisfactorily.
I am unable to view the TSB's or download them for the alarm sensitivity, any chance you can email them or do I need to ring jeep ?
You & everyone else - the days of free internet have been restricted.
Your dealer should have access to this:
TSB 08-005-09 FLASH: Alarm Sensitivity (export models)
I am not a dealer, i am a small workshop trying to service my clients. I have no access. Any chance someone has the bulletin handy so I can see if I have the ability to carry out the procedure ?
There are paid subscription services that have TSBs.
I had this one done at the dealer. It was a software update from Dodge.
1 - 12 of 12 Posts
