Flap install
Rate 4 out of 10
Install Time maybe 1 ½ hours
Cost $15.00 per pair
I wanted flaps, Dodge/Mopar doesn’t have them yet for the fronts, (R/T version anyway), so I opted for a universal fit available at our Local Canadian Tire, I assume at Pep Boys State size.
They come in 3 sizes, I found #1 fit the front, #3 for the rear.
A spare set of eyes help, position the flap on the car while having someone eyeball it for you from a distance, I marked the outline with masking tape
I find it much easier to jack up the car and remove the wheels, please use jack stands, and never work on a car with the jack alone.
Hold the flap according to the position you have established in step one, give it a slight tap with a hammer on the back side, this will in turn mark the position of the existing screws on the inside fender. One my R/T, there was one screw for the rear, Two for the front
drill a hole that you just achieved, remove the existing screw (7mm socket) and install the mud flap
The mudflaps come with screws, so add an extra one to the top and bottom as needed
Here’s a pic of the front, with the extra screw on the top edge
Continue your install around the car and things should come out fine
Final result
Rear
Front
I’ll follow with an overall pic once the car is clean and it stops raining
Rate 4 out of 10
Final result
Rear
Front
