21 - 24 of 24 Posts
i had the fogging a few times on my stock left tail light...
i changed with my buddys as he sold his caliber, but it came back... i sealed the complete housing with silicon and it came back....
i cleaned the sealing of the sockets and it came back....
i changed to the LED tails and had no problems...
:D
I've still got one for sale. It doesn't leak. Like I said before, thirty bucks plus shipping to your zip code in the lower 48. Shipping to Canada, Hawaii or Alaska would probably cost more than the tail light.
Remove tail light assembly, drain water out and let dry in sun. When satisfied that all water has evaporated, put a bead of black silicon around the lens and back housing and let dry before installing on car. I have had no problems since this fix! You can use low pressure compressed air and a blow gun to find the leak or leaks before you seal the housing. Just run a bead all the way around the lens.
Premium Member
I had moisture in mine not too long ago. I removed the tail lights and used a bottle dryer at my work to remove the moisture. All I
did was flip all the gaskets on the bulbs and the moisture hasn't come back since.
21 - 24 of 24 Posts
