1 - 9 of 9 Posts
But im getting 20" rims on mine, then diameter shouldnt be a problem should it ?
Do you have a spare wheel ?
Will your Calipers fit on a different sized rotor ?
You can't put a larger diameter rotor on, no matter if you are going with larger wheels, your calipers cannot accommodate them.
Exactly :smileup:
I've attached another picture for you Martin, and colored the part wich will limit it.
:wavey:
Discussion Starter #7
i See :) thank you, i have found som slitted ones from EBC that are the same size i will order those instead.
the srt4 has the chrysler 300C brake system... and with a minimum of 18" wheels...
the caliber has smaller brakes...
1 - 9 of 9 Posts
