1 - 10 of 10 Posts
A little something I have in mind for the chill zone. Not sure how I can go about accomplishing this, but I think it would look sweet to light it up in there. If anyone has any ideas, useful tips, criticisms, etc. let me know!
*'s don't necessarily denote light placement.
-Wilk
The Italian Admin
No clue on how to do it but I think it would look pretty cool :smileup:
Super Squirrel
all i can think of is a simple LED strip taped or glued to the top. ill try it out and post up once i get some money. But there s a spot on the right side of the glove box that isnt sealed or anything so u can run wires through pretty easy. dunno how that is on the chill zone though. Ill attempt it maybe this weekend. it looks really good
missing light in the golve box is one of those little things that get noticed after a while.
Do it.
Reactions: cassidee
Discussion Starter · #6 ·
Super Squirrel
wire positive to a power source and ground the negative lol somewhere in between put a switch lol u can also get away with a simple $20 streetglow LED strip from advance auto parts and have an extra for another use.
Discussion Starter · #8 ·
"wire positive to a power source and ground the negative lol somewhere in between put a switch lol"
Haha okay, fair enough. However, I'm more concerned with where said wiring should go. I'm literally at a loss, I have no experience with wiring.
If you can take off your center bezel then the feed at the back of the aux socket is a favorite (Cig lighter).
Ground use any convenient bolt to the metal frame when you are dismantling.
Reactions: cassidee
1 - 10 of 10 Posts
