1 - 1 of 1 Posts
17090
17082
17083
17084
17085
17088
17089
Cable Eyewear Technology Electronic device Wire No hyperflash with 50w 6 ohm resistor harness. 2 resistors for hi and low beam, make sure to mount on metal these things are hot enough to dab hash off of. The tail lights on the other hand cause an extra beep about 1 minute after starting up. Need to install resistor for those. No hyperflash though:
17086
17087
Also swapped Left license plate light for red because one light has to stay white.
Once again wouldn't have done it without you guys having so much info on here. I've never worked on cars before to this extent. Thanks Caliberforumz! THANKS @672aq and @Aleks , and everyone else on here!
1 - 1 of 1 Posts
