I searched on the forum for info about, is it possible to run jeep patriot rims on my 2010 dodge caliber are they the same backspace ? I know the bolt pattern is the same .the reason is I've got a person that's selling a set of patriot rims with sensors which I'm sure wont work with the dodge but I'm looking to put winter tires on them so will they work? Ps I know the tpms won't work
Patriot rims should be identical to Caliber. You can easily swap out Jeep centre caps with Dodge ones if that seems to bother you visually as well.
If original Chrysler sensors they should be recognised. Just drive a few miles, common with winter sets. The Jeep wheels are a good option. They do not have that Dodge diamond cut that promotes corrosion and take the Dodge centre cap.
The pressure sensors in the Jeep rims should work...Calibers automatically detect sensors and when it sees the same 4 sensors for a long enough period of time it'll realize they belong to your car and it'll adjust itself accordingly.
