Hi All,
I have very specific issue with my car
It's DODGE Caliber CRD SXT 2008
Enging is ECE (by checking 8th position of VIN - letter T)
Till now car has been driven for 185000 km, and 10 days ago I started to have issues in driving when engine temperature is on working level (issue is not shown on cold engine no matter on type of drive)
Issues are:
- twitching of engine with constant gas (keeping in same rpm/speed)
- shaking of car in driving when this twitching occurs
- it start only PENDING DTC:
1) P0269 with drive on highway (Injected fuel quantity cylinder 3, Balance fault)
2) P0266with drive in city (low rpm/speed) (Injected fuel quantity cylinder 2, Balance fault)
3) i get one time issue P0303, cylinder 3 misfire
* P0269 is in 80% of cases, P0266 only few cases, P0303 is shown only 1 time - but car never make MIL ON
I was in BOSCH service and Fiat-Chrysler service, but they say all is OK by diagnostic reading :(
Everything started after I had DTC for Powertrain P242B/P2084/P2080 - I foind one vire on connection jack that is broken and replace it. (picture 4)
ECU in same time erased all this errors and started with P0269/P0266/P0303 only when engine is HOT (picture 1-3).
When I turn off car, leave to cool down 5-10 minutes, power it again there is no DTC (picture 5)
On car are replaced all Injectors before 30000 km
I really need help if anyone can help me with this, since car is not drivable when issue start
Thank you so much!
Discussion Starter #2
solved
it was electric issue
wires from Sensor4 was damaged (due to heat they stared to break so easy)
solution was to change lot of wires
Glad to hear you got it figured out and fixed. I didn't have a clue as I don't own a CRD. I don't even own a Caliber anymore.
