My interior dome lights are all turning on when rotating dimmer on multifunction switch, if I rotate to any position but the first (off position) the interior dome lights are all on.
I was hoping the problem would be solved by swapping the multifunction switch. Swapping the part with one from a wrecked vehicle solved the problem I was having with right turn signal causing interior lights to come on, but I still can't make the instrument cluster bright without turning on interior lamps.
I'm stumped! Anyone run into this issue before?
EDIT: some added information, when i turn the headlights on, the instrument cluster is very dim, but I can't turn up the brightness without activating all the interior lights. the problem persists even though I changed multifunction switches
