281 - 300 of 336 Posts
I did this yesterday before I left work, roads were wet, so wasn't sure I was getting any better. but this morning the roads were dry and I actually got a tire squeel, never had that before, I am pretty impressed with this.
Discussion Starter · #288 ·
How often should we do this?
I only did it the first time, then after a new battery, and then after doing a TIPM reset to get my rear wiper working properly again. I know others that do it at every oil change.
Don't expect miracles.
The "procedure" calibrates the PCM to the gas pedal.
You'll get a much smoother response, and the pedal position vs. engine sound vs. road speed will feel much more "normal".
So i did this lil procedure and now i actually have a bit of a lag when i start off... So do you all think i should try this once more and maybe it will help ? Or does this take a while for the PCM to learn the style of driving.. Im sure some one has answered this before but i didnt want to read 29 pages of posts
patience glasshoppa - take your time
There are 2,900 after that and gradually you'll appreciate the idiosynchrocies of the ride and the collective.
Discussion Starter · #293 ·
Read the instructions carefully. The slower you do it without any fluctuation; the better the results.
Just did mine a few minutes ago....will take it for a spin in 45 mins or so and test my results.
OK...just did it...seems better from a complete stop, but when rolling, you can her the engine rev WAAAAY before the transmission kicks in to give you the speed you need.
Discussion Starter · #297 ·
should I do this procedure on a periodic basis or once is good?
I only did it the first time and after I replaced the battery and when I did a TIPM reset. Some do it as often as every oil change.
I def. noticed a change in the sync between the engine and CVT.
I did not however notice a change in the dead spot from a stopped position -- still that 1/2-3/4 sec delay before punch. I repeated this procedure 2x - the 2nd time I actually used my hand and visually watched and counted as I depressed -- 20sec down, 20 sec up, let sit for an hour or so.
I may retry again tonight using a 30 sec interval instead, and let it sit overnight.
Best not to "punch" the CVT or any drive by wire system. They don't quite know how to respond to a "step change" in input.
Modern systems work best with a steady moderate push to the floor.
The system "understands" that type of input much better and will give you surprisingly good acceleration.
Try it - you'll see.
