Hi
, My Uptown has the 17" tires. I'm going to downsize the tire to 15" for my winter tire.
I have one set of 15" rims from Ford Taurus and another set of 15" rims from Toyota Sienna. I'm wondering if they are compatible with Caliber or not? Following are the datasheet links of those 3 types of rims. Except the rim size, what else should I look at to ensure that match my car?
Any advice? Besides, the car has the tire sensor since I can check the tire pressure on the dashboard. Can I use the regular winter tires/rims?
In that case, does the tire sensor still work? Thanks in advance!
1. Tires for Dodge Caliber 2010
http://www.wheel-size.com/size/dodge/caliber/2010/
2. Tires for Ford Taurus
http://www.wheel-size.com/size/ford/taurus-sesel/1996/
3. Tires for Toyota Sienna
http://www.wheel-size.com/size/toyota/sienna/
The basic SE uses a Tire and wheel that is 15". Plug that in and you should get a combo that fits.
Thank you for your advice! You are right, SE uses the 15" wheel and I believe it will fit my Uptown as well if I have the 15" SE wheel. Are you saying I have to use the wheel that initially designed for Caliber. No any "compatible" wheel can be used?
No, anything that is listed as compatible. But I did just realize that the Uptown is the same as the R/T. That would mean the clearance on the calipers could lead to rubbing. I'm just going from memory and believe that was the case another member found. You may find that you are stuck with 17".
Thanks a lot for your information! Good to know that.:Wow1:
