161 - 180 of 181 Posts
Discussion Starter · #162 ·
each relay ?
We just use one relay, no ?
1 relay control 2 ballast.
Some people use multiple relays. One for each low beam and one for each high beam. If you only have one; then you only need to do that one.
Discussion Starter · #164 ·
ok thx a lot, I'll try and let's you know.
P.S.: Random diode ? or axactly one type ?
General purpose with ratings for a 12V system.
1N4004 (1A 400PIV) or the like works well for relay coil surge suppression. I use them all the time in industrial machine control panels, across relay and solenoid valve coils.
One relay for two ballasts - are the contacts rated high enough?
Inadequately rated relay contacts can cause all sorts of weak power, even flickering lights.
To estimate needed contact rating - add the current draw of each ballast and multiply by two.
ex. 2 5A ballasts = 10A total load. The relay should be rated at 20A or more to insure good power to the ballasts and long relay life.
Discussion Starter · #170 ·
Ok so I have hids that operates on a 35v system output and a 13-16v input. So what relay would i need for the hids to work??
You need to know the amps they draw. The 12 volt 40 amp relay is what you need, but knowing what each ballast's current draw will determine if you need 1 or 2 relays.
OK, I guess that I'm on the same boat has everyone else. I don't fully understand but here goes.
09 Caliber
HID kit bought online.
I have the Relay Harness connected to the Battery and the Ground is connected to the Chassis. There is only one Relay on the Harness. Each Ballast has it's own Capacitor and from there it goes to the HID.
The Lights do flicker here and there but now I noticed that I can't change to them to low or high, they simply stay on low. That's strange...... after a while they did just turn off but if I turned on the High beams they came back on but only in low beam.
Should I try the 10 ohm Resistors first on the Harness that is feeding the Relay for the HID and move on from there?
I will try to take some pics of it soon.
Hi Prop1,
I am having the same issue and was looking to perform this ingenious fix. I'm not unskilled mechanically but wiring isn't my stron suit. The drawing seems to be unavailable or can't be displayed for some reason. Any chance you could repost it?
You can do it on your own risk (lead colours on drawing are different than those under the hood)
If you have an american bulb other than H4 -no matter, it is basicly all the same.
Text Line Diagram Font Parallel
It is much better to have two relays than just one (for both sides).
One relay case -if it brakes down - you will have no lights at all.
With two relays is much safer...
Hi, i can't see the diagrams, anyone have the pictures?
I put a LED canbus headlight, but with the low beam i have flickering problem, the LED flicker a couple times and then turn off, but the high beam works perfectly, anyone have this problem and know how to fix it?
This topic comes up often. Those Cheap HIDs sold on ebay that never work on the Caliber because of the TIPM. I figured it was time to address it with the only known work around to make them work.
You'll need relays similar to this:
relay rated 12V @ 40A
Weatherproof inline fuse holders similar to this:
And this drawing:
Is there someone who have a picture of this mod? I've got a low beam failure on the drivers side so O want to connect the low beam of the passender side via a relay and fuse. But what do I exactly know and what is the correct diagram?
A big thanks!
Hans
The embedded attachments were all lost with migration of the forum to different platforms. The first two were just generic images of an inline fuse-holder and a 40A automotive relay. The wiring diagram showed the signal wire being a feed from the switched side of the pass lamp. The power feed and ground points will be your choice.
Thanks a lot Aleks.
That's clear now. Regarding the fuse, hoe much A does the fuse needs to be?
I will power the headlight of the drivers side directly from the battery.
So I know which tot buy.
Thanks again.
