Hi guys,
I'm having an issue with a noise that's causing me some concern. I have an '07 Caliber SE, manual transmission, 1.8L. The noise started when I replaced the alternator. I originally replaced the alternator due to the decoupler pulley, but the alternator itself also needed to be replaced. The noise is a high pitched whine, not like the turbo noise I have read about, and only occurs when the vehicle is in gear and I accelerate. First and second gear are faint, but the faster I go the louder it gets; there is no pitch change. When going 70+ it sounds like I'm going to murder my vehicle and there is a "humming" feeling in my pedals and steering wheel. If I push in the clutch a toe's length while still pushing in the gas pedal the noise stays. There is no reaction when I downshift or idle. This issue only happens when I push in the gas pedal and in gear. Has anyone had this problem or have an idea of what the issue may be? Thank you so much!
