I have a 2012 caliber. My high beams will flick on, but they won’t stay on. Also, my cabin/dome light will not turn on unless my right turn signal is also on. I am not very electronically oriented, and I’m curious to see if anyone else has come across similar problems and/or possible solutions.
Regarding the high beams, you pull the stalk towards you to flash them,but push the stalk away from you to lock them on. Does pushing the stalk away from you not lock them on?
IIRC dome light is controlled by the turn signal stalk so if it only works when the right turn signal is on, it sounds like your stalk assembly is at fault (especially if you're using the high beams correctly). Replace the stalk.
Yes, the brights only flick on for less than a second when in the forward (lock) position.
