1 - 7 of 7 Posts
send them back because they are going to flicker and go crazy invest in a decent set. I got mine for around 200, from an old supporting vendor. 3 years and not a flicker once. They were just plug and play, no extra work!
Those HIDs are probably going to flicker as XXX mentioned. You can use resistors and relays if you know what you're doing, or you can spend some money and get a quality set.
what about if i buy a hid foglight will do the same thing....
All the cheap ones will flicker without added electrical components and wiring.
1 - 7 of 7 Posts
