hello, i have one question, if i turned on low beam headlight, and want to turn on high beam, low beam light is turning of and only high beam lights is on, it's possible to turning on both when i turn on high beam light?
No
It’s a modification. You’ll need to wire in a relay and a couple high-power diodes.
There are a few videos on Youtube to help get you the idea. Fairly simple.
Running power to both filaments will generate heat and cause bulb failure in a halogen, maybe not with LED.
If you want near illumination when driving on high beams consider using the fog light positions.
Reactions: 672aq
