Hi,
Please for support. I just have the error code „Oil Temperature Sensor Circuit Low P0198-engine Oil Temperature Sensor Circuit High“
Check Engine Light is on. Before replacing the sensor, I was able to erase the error that reappeared after a few days. After the sensor replacement I can't erase the error and the light is always on. Thanks
Dodge Caliber R/T 2008
It was aftermarket one, but then I tried with the old one and was the same…it is no longer possible to erase the error.
Could be loss of signal, check the wiring and connector.
