Hi from England. Need to pull above fuse prior to having a mot (English test) Local garage states light not causing a problem and has stayed on for many years again no problems. What fuse number am I looking for and its colour. Thank JohnR
You have a engine warning light and the shop told you that you that the problem is the light itself and that you should pull a fuse to disable the light?
This is not a likely scenario. Also, there is no fuse that just feeds the warning light.
Get someone to use code reader to read the problem codes out of the computer so you can figure out exactly what is wrong.
