Currently have the following lights come on just after starting engine
Esp
Handbrake
Abs
Espbas
any ideas please
Seemingly unrelated warning lights like this often indicate a shorted wire in the wiring harness that runs from the TIPM to the cabin behind the front driver's side wheel liner. Pull the wheel/liner and see if the harness has rubbed through anywhere, especially the bend where it exits the engine compartment.
I had this happen to mine in December, due to corroded wires. You have to buy the complete harness but I just had to have the ABS wiring replaced. Parts and labor was $664.75 at the Dodge dealer.
They will when the corrosion gets a bit worse. On my car, the lights didn't come on at first start up for the first day. They did come up at start up about the second day.
