Hi All,
I'm hoping to hear some thoughts about a CVT situation that happened to me this morning. On my way to work today around 6 am, I started to hear a whining sound (similar to this sound... https://youtu.be/VNkEZt0mr-4) about 4 miles in to my drive. It got higher pitched as I accelerated, but I was never going over 45 mph because I was in town and that was the speed limit. I thought the car was driving normal otherwise but now that I think about it the RPMs may have been running high. I shifted into neutral and the sound went away, I shifted back into drive and the sound came back. I continued to drive for another mile or two until the transmission overtemp light came on. I don't know if it went into "limp mode" because I immediately took my foot off the gas and coasted to a stop on the side of the road and turned off the car. After about 5 minutes I started the car back up, turned around and headed home with the car acting completely normal. I came home and searched for the problem and came across this forum.
Reading through this and a couple of other threads mentioning wiring issues causing CVT problems made me think to look under the drivers side of the dash for loose wires and I maybe found a loose connection going into the white connector that is attached to the brake pedal arm (I have no idea what that part is called). I don't know if this connection has anything to do with anything, but when I pushed it in it did seem to seat a little better and I thought I felt a slight click. Anyways, I went back out and drove about 40 miles, 5 miles of city driving to the freeway then 15 miles on the freeway going 70 mph before turning around and heading back the same way. The car was driving normal the whole way... no weird sounds and no CEL or transmission temp lights came on.
The car is a 2007 Caliber SXT with CVT that my wife and I have owned since July of 2006 and it has 124k miles on it. We've done most of the normal servicing, regular oil changes and changed out the spark plugs a year or so ago when our garage recommended it. No real problems with it other than the oil pan gasket was changed out last month due to a slow leak from the pan. Also, the CEL has been coming on and going off for the last 3 or 4 months. The code that shows up is P0420 and it stays on for a day or two then goes off on its own. Today is the first day I've had any issues hearing this sound or with the transmission light illuminating.
So after my long winded backstory, I do have a couple of questions. Could that wiring harness that I think my have been loose caused the problem with the whining sound and the overtemp light coming on? I'm hoping there is nothing wrong with the transmission itself since the problem seemed to resolve itself, is this an unreasonable thought? What's the best way to diagnose the problem since it's no longer doing it and it didn't trip a CEL light or log any other fault codes? I could take it to a garage but they won't be able to tell me anything since its not doing it anymore, or is there something specific I should be asking them to do? Is the intermittent P0420 code more serious than I originally thought and causing problems with the CVT? Sorry to sound so ignorant and needy, I just really don't know what to do other than keep driving it until it happens again, and just cross my fingers that it doesn't. Any thoughts or ideas are appreciated.
