I have a 1997 Dodge calibre, The horn, the cruise control, and AC are not working. I replaced the control module, The AC worked, no horn or cruise, In the car would not accelerate above idle?? Put old control module back in, car runs fine but still no AC no horn no cruise? Any ideas??? Thank you
For the AC, have you checked to make sure there is refrigerant in the system? I had another car that wouldn't let the AC turn on if the refrigerant was low (pressure switch).
The replacement control module may need to be programmed to the car before it'll work correctly, or it could be defective (if it's a used module). The horn and cruise could very well be a bad clockspring.
Using a Starscan tool - only at the Dealer.
