CaliburGuy's Turbo journey
13657 Views 350 Replies 12 Participants Last post by  CaliburGuy2021
2
Hello Im new here.
I dont know if anyone is here still but i am looking for a tuning program like HP Tuner or something like that for my 2007 Caliber 1.8 5speed Manual.
I am planning on slapping a turbo on it but i need to know what management systems are available for this platform.
I have searched here but have only seen people talking about CVT, 2.0 and 2.4 and not to do it. nothing about the 5 speed other then the legend of
Turbo07RT
anyways all this was 10 years ago. It is 2020
5/10/22- this was not my Daily Driver when I started. But now I drive it like my Daily Driver.
Thank you and hope to get some answer and to also be able to help if possible! I will be updating with my findings as well.
Kind Regards to you all.
I will post Updates below here so you do not have to search all the pages.
ODM start -
January 7 22
5 psi - 22244
April 1 22
7 psi - 25300
April 4 22
10 psi - 26482
5/7/22 - Dyno Results 10psi
205.32WHP 197.13TQ
Rectangle Slope Parallel Font Pattern
4/9/22 - Dyno results 7psi
169.80 WHP and 161.59 TQ
Rectangle Slope Plot Font Line
Hello Im new here.
Turbo07RT
anyways all this was 10 years ago. It is 2020 and this is not my DD.
See less See more
321 - 340 of 351 Posts
3
HI CaliberGuy, I'm getting closer to installing an Eaton M90 supercharger on my Caliber R/T.
How did you mount your intake air temp sensor? I'm assuming you mounted it between the intercooler and throttle body. Did you use an adapter of some kind?
Awesome man. I think this would be the first supercharged that i have seen!
So i just drilled a small hole into the lancer railart hose and popped it in like below. I also had to extend the wires a little bit. I got another sensor and wires from the junkyard with working clips
Motor vehicle Automotive design Bag Automotive tire Personal protective equipment
Automotive lighting Sports equipment Bag Hood Automotive design
Motor vehicle Automotive fuel system Automotive design Automotive exterior Hood
See less See more
To be honest idk but you would think so... but the car holds boost fine. I would like to find a better solution.
Reactions: 1
10
So an update! I got my FPR and return line setup! I also found a fpr block of plate. I had to do a bit of drilling and stuff. This is the first attempt and i think i would have put the fittings in another spot.
Anyways. The problem i am having is that i am now only getting 20 psi at the fuel rail and 1 bar at the fpr when the pump is on or priming. I am thinking they have given me a 1 bar fpr... so i am waiting on another one tomorrow also the return window closed 3 days ago 😭.
Hood Car Motor vehicle Speedometer Automotive tire
Fluid Liquid Gas Toilet Auto part
Gas Machine Auto part Metal Carmine
Hood Automotive lighting Automotive tire Wheel Steering wheel
Gas Auto part Automotive design Electric blue Metal
Light Motor vehicle Automotive exterior Automotive air manifold Hood
Porcelain Gas Serveware Liquid Ceramic
Gas Automotive tire Engineering Machine Automotive design
Automotive lighting Motor vehicle Computer keyboard Automotive design Automotive exterior
Automotive tire Light Tire Automotive lighting Motor vehicle
See less See more
2
Fuel tank canister i used (use your stock fuel arm!)
Product Jaw Font Screenshot Audio equipment
This is the blockoff plate i used to defeat the in take fpr.
Font Parallel Office supplies Rectangle Screenshot
See less See more
Okay so even after all of this and i got another FPR to test i still am only getting 21.77 psi of fuel pressure at the rail. i am wondering if i am loosing pressure due to the stock holder... kinda stumped
Is that regulator the blue thing?
Is it not variably adjustable?
Why do you not have the rail pressure display routed in such a way where you can see it from inside the car?
yes currently have a replacement on it.
It should go up to 85 psi but the car needs 65 psi
haha very good question. I am still learning all this stuff so i am winging it lol. I just put a camera under the hood and record it.
Reactions: 1
2
White Product Fluid Gas Auto part
Hood Automotive tire Azure Motor vehicle Automotive lighting
I put some tank weild on these open ports to see if they where leaking
See less See more
Is the fuel pump limited to only that amount?
no it is not. Also plugging the above ports worked!
The plug failed and had a loss of pressure. Now i need to figure out how to close thos ports off. I think if the fpr block off plate had a part extending into that area it would have solved this. Any suggestions on how to close the port off or block that port completely.
(Update) I filled up the inside this time instead of the outside lol. Ill let you all know how this works
I think this is what i should have got
2
So far after filling the inside is working way better than the outside lol. anyways.
Land vehicle Speedometer Motor vehicle Gauge Measuring instrument
Vehicle Motor vehicle Gauge Speedometer Automotive design
John i do have a question. I have noticed that my breaks heat up wayyyyy faster then before. (I do have boots on the rear tho). With that supercharger are you using the same break system?
See less See more
Got the car on the dyno today!
The results
271 Whp 12.8 psi peak and 10 psi hold.
300 TQ
E85.
I need to adjust the curve a bit more tho. This is with 3 inch down pipe - 3 inch cat to stock 1.8 exhaust = ) stock 1.8 ecm
Reactions: 1
I run the stock R/T brake caliper and rotor sizes.
Front pads: Porterfield ST-43
Rear pads: Porterfield R4
Rotors: EBC plain rotors (not slotted or drilled)
Fluid: Motul RPF 600
They are racing pads, too noisy for street. That said, they are very powerful, braking from 100+mph down to 20-30 mph 100 or more times over an 8 hour session...no fade at all.
Reactions: 2
Oh i see, Yeah i am going to look into the rt calipers. I put some new tires on and the car stops wayyy better now then before lol. But i still need to convert to disk in the rear. cool and thanks man!
...i still need to convert to disk in the rear. cool and thanks man!
I would not bother with that, Porterfield will make custom brake shoes for your drums with whatever compound you want.
Reactions: 1
