301 - 320 of 323 Posts
· Registered
Discussion Starter · #301 ·
Sooo this project has just kept getting worse with srt 4 motor 🫠. I am starting to think i would be having more fun with another 1.8 😂. Anyways
Now i got a few things needing to be fixed.
I put a new oil pan and it is leaking bad
Video below
Is this oil pump chain to loose?
Video below
I think the oil feed line has a small leak as well..
Now the worse part... the junkyard i got the motor from lied. They said it had 125k miles and i checked the vin online and it says 201k miles..
I am kinda lost atm.
· Registered
While still fumbling with the buckles in my straightjacket;
Can one make one of these motors out of old-school metal?
Cast iron? Something not made of weak aluminium. Titanium, maybe?
Would this be a cheaper idea?
454 Hemi doesn't fit? 😶
· Registered
There is no connection point from the factory. You will have to fabricate a connection point or find an aftermarket connection. Maybe something that goes in between the fuel raid/fuel line connection point.
Let me know if you find one
· Registered
Discussion Starter · #307 ·
yeah that is what it is looking like. A guy on the fourms was asking about this a while ago and he put the sizes on there. So i am trying to see what i can come up with.
· Registered
Take a look at the factory service manual. There must be a factory procedure used in the dealership service bays to check the fuel pressure. They probably have a special adapter.
· Super Moderator
FUEL SYSTEM PRESSURE
400 kpa ±34 kpa (58 psi ± 5 psi)
Manual shows tool attachment but not where
Font Auto part Drawing Fashion accessory Elbow
Reactions: CaliburGuy2021
· Registered
Discussion Starter · #311 ·
i bought this aand this.
you all think this will work? haha
· Registered
Discussion Starter · #317 ·
Quick update. I will be replacing the timing/oil pump chain and fixing the oil pan leak. Then the following week I will be changing the fuel system to a return style system instead of the current returnless system due to fuel pressure issue. Then get back to tuning on E85.
· Registered
Discussion Starter · #318 ·
Got the Timing chain done and car has been driving good. Now the I am just waiting on the JMB fuel rail to come in tomorrow to change the fuel system.
was my first time doing a timing chain job. Was not as scary as i thought.
Also no leaks = )
· Registered
Discussion Starter · #319 ·
Had to send the fuel rail back due to the port on the rail being to big.
While they are fixing that. I was wonder if anyone knows how to defeat the stock fuel pressure regulator? I drilled a screw in the middle to hope that it nulls it.
If i take it out fuel leaks out. I may need something to block it.
Aftermarket fuel canister.
screw in the picture is normal a hole.
Hood Automotive tire Automotive lighting Vehicle Tire
· Registered
HI CaliberGuy, I'm getting closer to installing an Eaton M90 supercharger on my Caliber R/T.
How did you mount your intake air temp sensor? I'm assuming you mounted it between the intercooler and throttle body. Did you use an adapter of some kind?
