Caliber is full of acronyms - here's a guide
ABS - - Anti-lock Brake System
AMP - - AUDIO AMPLIFIER
AWD - - All Wheel Drive control module
BAS - - Brake Assist System
CAN - - Controller Area Network data bus
CCN - - Cab Compartment Node
CFR - - Constant-force Retractors
CGW - - Central GateWay
DLC - - Data Link Connector
DTC - - Diagnostic Trouble Code
EARS - - Enhanced Accident Response System
EBD - - Electronic Brake-force Distribution
ECM - - Engine Control Module
EMIC - - ElectroMechanical Instrument Cluster
ESC - - Electronic Speed Control
ESP - - Electronic Stability Program
EVIC - - Electronic Vehicle Information Center
HAS - - Hill-start Assist
HDC - - Hill-descent Control
HFM - - HANDS FREE PHONE MODULE
HSM - - Heated Seat Module
HVAC - - Heating, Ventilation & Climate control
ITM - - Intrusion Transceiver Module
LATCH - - Lower Anchors and Tethers for CHildren
LIN - - Local Interface Network data bus
OBD - - On-Board Diagnostics
OCS - - Occupant-classification System
ORC - - Occupant Restraint Controller
PCM - - POWERTRAIN CONTROL MODULE
RKE - - Remote Keyless Entry
SAS - - Steering Angle Sensor
SCCM - - Steering Column Control Module
SCM - - Steering Control Module
SDARS - - Satellite Digital Audio Radio Service
SKREEM - - Sentry Key REmote Entry Module
TCM - - Transmission Control Module
TCS - - Traction Control System
TIPM - - TOTALLY INTEGRATED POWER MODULE
TIRM - - Traffic Information Receiver Module
TPM - - Tire Pressure Monitor
TPMS - - Tire Pressure Monitoring System
TSB - - Technical Service Bulletin
WCM - - Wireless Control Module
Reactions: exituponarrival
DODGE dictionary
Acronyms Glossary
MOPAR = Motor Parts or Chrysler Corporation Motor Parts Division
SE = Standard Edition-Base Trim Level
RT or R/T = Road and Track- Mid Trim Level
SRT (Street and Racing Technology)
A/C Air Conditioning
AAT Ambient Air Temperature
ABM Antilock Brake Module
ABS Antilock Brake System
ACC Adaptive Cruise Control
ACT Actuator
AFLS Adaptive Front Lighting System
AHBM Automatic High Beam Module
AHLM Automatic Headlamp Leveling Module
AHM Auxiliary Heater Module
ALS Active lighting system (lights follow steering)
AMP Amplifier
APM Adjustable Pedal Module
APPS Accelerator Pedal Position Sensor
APS Adjustable Pedals System
ASCM Air Suspension Control Module
ASD Auto Shut Down
ASBS Automatic Sway Bar System
AT Automatic Transmission-Rear Wheel Drive
ATC Automatic Temperature Control
ATF Automatic Transmission Fluid
ATX Automatic Transmission-Front Wheel Drive
AWD All Wheel Drive
AZC Automatic Zone Control
BARO Barometric
BCM Body Control Module
BPS Bladder Pressure Sensor
BSM Blind Spot Module
BTS Belt Tension Sensor
BTSI Brake Transmission Shift Interlock
BUX Built-Up Export
CAB Controller Antilock Brake
CAN Controller Area Network
CAN IHS Controller Area Network - Interior High Speed
CCD Chrysler Collision Detection
CCN Cabin Compartment Node
CGW Central Gateway
CHMSL Center high mount stop lamp
CKP Crank Position Sensor
CKT Circuit
CMP Camshaft Position Sensor
CMTC Compass/Mini-Trip Computer
CPA Connector Positive Assurance
CTM Compass Temperature Module
CVI Clutch Volume Index
DAB Driver Airbag
DC Direct Current
DCHA Diesel Cabin Heater Assist
DDM Driver Door Module
DEF Diesel Exhaust Fluid
DISP Display
DLC Data Link Connector
DMFL Door Module Front Left
DMFR Door Module Front Right
DMRL Door Module Rear Left
DMRR Door Module Rear Right
DOHC Dual Over Head Cam
DR Door
DRBIII Diagnostic Readout Box, 3rd Generation
DRV Driver
DTC Diagnostic Trouble Code
DTCM Drivetrain Control Module
EATX Electronic Automatic Transaxle
EBL Electric Back Lite (Rear Window Defogger)
ECM Engine Control Module (Diesel)
ECT Engine Coolant Temperature Sensor
EGR Exhaust Gas Re-Circulation
EMCC Electronically Modulated Converter Clutch
EOM Electronic Overhead Module
EPS Electric Power Steering
ESM Electronic Shift Module
ETC Electronic Throttle Control
ETS Evaporator Temperature Sensor
EVBP Electronic Variable Brake Proportioning
EVIC Electronic Vehicle Information Center
FCM Front Control Module
FCV Flow Control Valve
FDCM Final Drive Control Module
FEMCC Full Electronically Modulated Converter Clutch
FSM Folding Seat Module
GCC Gulf Coast Countries
GEN Generator
GPEC Global Powertrain Engine Controller
HCU Hydraulic Control Unit
HE Hall Effect
HFM Hands Free Module
HIDT High Intensity Discharge Transducer
HSM Heated Seat Module
HVAC Heater Ventilation, Air Conditioning
I/C Integrated Circuit
IAC Idle Air Control Motor
IAT Intake/Inlet Air Temperature Sensor
ICU Integrated Control Unit
ICS Integrated Center Stack
IOD Ignition Off Draw
IP Instrument Panel
IPC Instrument Panel Cluster
IPM Integrated Power Module
IR Infrared
IRT Intelligent Recovery Timer
ISS Input Speed Sensor
ITBM Integrated Trailer Brake Module
ITM Intrusion Transceiver Module
JBLK Junction Block
JTEC Jeep & Truck Engine Control Module
KDB2 Keyboard Data Bus, 2nd Generation
KNB Knee Blocker Airbag
KS Knock Sensor
LDP Leak Detection Pump
LDU Lower Drive Unit
LED Light Emitting Diode
LIN Local Interconnect Network
LHD Left Hand Drive
LR Low/Reverse Clutch or Pressure Switch
LRSM Light Rain Sensor Module
LT Left
LU Lockup
MAP Manifold Absolute Pressure Sensor
MDS Multi Displacement System
MIC Mechanical Instrument Cluster
MIL Malfunction Indicator Lamp
MLS Multi Layer Steel
MSMAPM Memory Seat/Mirror/Adjustable Pedals Module
MSMD Memory Seat Module
MT Manual Transmission-Rear Wheel Drive
MTC Manual Temperature Control
MTV Manifold Tuning Valve
MTX Manual Transmission-Front Wheel Drive
MUX Multiplex
NAV Navigation
NGC Next Generation Controller
NVLD Natural Vacuum Leak Detection
O2S Oxygen Sensor
OAT Outside Air Temperature
OBD On Board Diagnostics
OBD-I On Board Diagnostic specification 1 (1991-1995)
OBD-II On Board Diagnostic specification 2 (1996 and up)
OCM Occupant Classification Module
OCS Occupant Classification System
OCSVR Occupant Classification System Verification Required
OD Overdrive Clutch or Pressure Switch
ODO Odometer
ORC Occupant Restraint Controller
OSS Output Speed Sensor
P/M Pump Motor
PAB Passenger Airbag
PASS Passenger
PCI Programmable Communication Interface
PCM Powertrain Control Module
PCV Positive Crankcase Ventilation
PDC Power Distribution Center
PDM Passenger Door Module
PEM Passive Entry Module
PEMCC Partial Electronically Modulated Converter Clutch
PEP Peripheral Expansion Port
PLG Power Liftgate
PLGM Power Liftgate Module
PLU Partial Lockup
PSD Power Sliding Door
PSDM Power Sliding Door Module
PSDML Power Sliding Door Module Left
PSDMR Power Sliding Door Module Right
PSM Programmable Special Module
PSI Pounds Per Square Inch
PTCM Power Top Control Module
PTIM Police and Taxi Interface Module
PTS Parktronics
PWM Pulse Width Modulated
PWR Power
RCM Roof Control Module
REV Reverse Clutch
RF Radio Frequency
RHD Right Hand Drive
RKE Remote Keyless Entry
RT Right
RTV Room Temperature Vulcanizing
RX Receive
S/C Speed Control
SAB Seat Airbag
SAS Steering Angle Sensor
SBEC Single Board Engine Controller
SBM Switch Bank Module
SBS Seat Belt Switch
SBT Seat Belt Tensioner
SCA Shift Cover Assembly
SCM Steering Control Module
SCCM Steering Column Control Module
SDAR Satellite Digital Audio Receiver
SDARV Satellite Digital Audio Receiver Video
SKIM Sentry Key Immobilizer Module
SKIS Sentry Key Immobilizer System
SKREEM Sentry Key Remote Entry Module
SKREES Sentry Key Remote Entry System
SLPK Solenoid Pack
SOHC Single Over Head Cam
SOL Solenoid
SRS Supplemental Restraint System
SRV Short Runner Valve
SSV Solenoid Switch Valve
SUNR Sunroof
SW Switch
SWS Seat Weight Sensor
TCC Torque Converter Clutch
TCCM Transfer Case Control Module
TCM Transmission Control Module
TCS Traction Control System
TGW Telematics Gateway
TIP Throttle Inlet Pressure
TIPM Totally Integrated Power Module
TIRM Traffic Information Receiver Module
TM Trailer Module
TP Throttle Position
TPM Tire Pressure Monitor
TPMS Tire Pressure Monitor System
TPS Throttle Position Sensor
TRD Torque Reduction
TRS Transmission Range Sensor
TX Transmit
UD Underdrive Clutch
VES Vehicle Entertainment System
VFD Vacuum Fluorescent Display
VPWM Variable Pulse Width Modulated
VSIM Vehicle System Interface Module
VSS Vehicle Speed Sensor/Signal
VTSS Vehicle Theft Security System
WCM Wireless Control Module
WIN Wireless Ignition Node
WOT Wide Open Throttle
WSS Wheel Speed Sensor
What are the sensors, what do they do, how do they work?
Car running rough, won't start, dies, limp home mode (to protect the engine).
Even when there is no fault the lack of an expected signal from a sensor can create a symptom
