P000a-bank 1 Camshaft 1 Position Slow Response
P000b-bank 1 Camshaft 2 Position Slow Response
P0010-bank 1 Camshaft 1 Position Actuator Circuit Open
P0011-bank 1 Camshaft 1 Position Target Performance
P0013-bank 1 Camshaft 2 Position Actuator Circuit Open
P0014-bank 1 Camshaft 2 Position Target Performance
P0016-crankshaft/camshaft Timing Misalignment Bank 1 Sensor 1
P0017-crankshaft/camshaft Timing Misalignment Bank 1 Sensor 2
P0031-o2 Sensor 1/1 Heater Circuit Low
P0032-o2 Sensor 1/1 Heater Circuit High
P0037-o2 Sensor 1/2 Heater Circuit Low
P0038-o2 Sensor 1/2 Heater Circuit High
P0071-ambient Air Temperature Sensor Performance
P0072-ambient Air Temperature Sensor Circuit Low
P0073-ambient Air Temperature Sensor Circuit High
P0106-manifold Absolute Pressure Sensor Performance
P0107-manifold Absolute Pressure Sensor Circuit Low
P0108-manifold Absolute Pressure Sensor Circuit High
P0111-intake Air Temperature Sensor Performance
P0112-intake Air Temperature Sensor Circuit Low
P0113-intake Air Temperature Sensor Circuit High
P0116-engine Coolant Temperature Sensor Performance
P0117-engine Coolant Temperature Sensor Circuit Low
P0118-engine Coolant Temperature Sensor Circuit High
P0121-throttle Position Sensor 1 Performance
P0122-throttle Position Sensor 1 Circuit Low
P0123-throttle Position Sensor 1 Circuit High
P0125-insufficient Coolant Temperature For Closed-loop Fuel Control
P0128-thermostat Rationality
P0129-barometric Pressure Out Of Range Low
P0131-o2 Sensor 1/1 Circuit Low
P0132-o2 Sensor 1/1 Circuit High
P0133-o2 Sensor 1/1 Slow Response
P0135-o2 Sensor 1/1 Heater Performance
P0137-o2 Sensor 1/2 Circuit Low
P0138-o2 Sensor 1/2 Circuit High
P0139-o2 Sensor 1/2 Slow Response
P0140-o2 Sensor 1/2 Signal Inactive
P0141-o2 Sensor 1/2 Heater Performance
P0171-fuel System 1/1 Lean
P0172-fuel System 1/1 Rich
P0196-engine Oil Temperature Sensor Performance
P0197-engine Oil Temperature Sensor Circuit Low
P0198-engine Oil Temperature Sensor Circuit High
P0201-fuel Injector 1 Circuit/open
P0202-fuel Injector 2 Circuit/open
P0203-fuel Injector 3 Circuit/open
P0204-fuel Injector 4 Circuit/open
P0218-high Temperature Operation Activated
P0221-throttle Position Sensor 2 Circuit Performance
P0222-throttle Position Sensor 2 Circuit Low
P0223-throttle Position Sensor 2 Circuit High
P0261-fuel Injector 1 Circuit Low
P0262-fuel Injector 1 Circuit High
P0264-fuel Injector 2 Circuit Low
P0265-fuel Injector 2 Circuit High
P0267-fuel Injector 3 Circuit Low
P0268-fuel Injector 3 Circuit High
P0270-fuel Injector 4 Circuit Low
P0271-fuel Injector 4 Circuit High
P0298-engine Oil Temperature Too High
P0300-multiple Cylinder Misfire
P0301-cylinder 1 Misfire
P0302-cylinder 2 Misfire
P0303-cylinder 3 Misfire
P0304-cylinder 4 Misfire
P0315-no Crank Sensor Learned
P0325-knock Sensor 1 Circuit
P0335-crankshaft Position Sensor Circuit
P0336-crankshaft Position Sensor Performance
P0339-crankshaft Position Sensor Intermittent
P0340-camshaft Position Sensor Circuit-bank 1 Sensor 1
P0341-camshaft Position Sensor Circuit Performance-bank 1 Sensor 1
P0344-camshaft Position Sensor Intermittent-bank 1 Sensor 1
P0351-ignition Coil 1 Circuit
P0352-ignition Coil 2 Circuit
P0353-ignition Coil 3 Circuit
P0354-ignition Coil 4 Circuit
P0365-camshaft Position Sensor Circuit-bank 1 Sensor 2
P0366-camshaft Position Sensor Performance-bank 1 Sensor 2
P0369-camshaft Position Sensor Intermittent-bank 1 Sensor 2
P0420-catalyst 1/1 Efficiency
